amallam
Joined: 22 Mar 2006 Posts: 6 Location: Lancashire, United Kingdom Thanked: 0 times
Posted: Wed Mar 22, 2006 3:22 pm Post Subject: 3 Amp FCU 4 a cooker hood |
Can I take the supply (via a 3 amp FCU) for a cooker hood from a domestic lighting circuit?
Regards, |
JohnD
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Wed Mar 22, 2006 3:33 pm Post Subject: |
Yes, if it's an ordinary fan and lights of low wattage.
Some people will say you don't need an extra fuse, but the FCU will give you isolation (if switched) so is a handy way to do it; and in the event of a fault might save all the lights going out (but you can't rely on it as the 6A MCB will probably trip at the same time) |
amallam
Posted: Wed Mar 22, 2006 3:54 pm Post Subject: Cooker Hood |
It's extraction rate is 500m cubed/hr and has 2 x 40w lights.
Is this still OK? |
JohnD
Diesel9a1
Joined: 02 May 2006 Posts: 14 Location: Kent, United Kingdom Thanked: 0 times
Posted: Tue May 02, 2006 9:32 am Post Subject: Extractor Hood |
So it is not necessary to install a separate FSU for the hood?
Is a viable / allowable solution to put a switched socket (on the ring main) located in the hood out of sight, then fix a normal plug to the hood flex and fuse to 6A?
Pete |
JohnD
Posted: Tue May 02, 2006 11:54 am Post Subject: |
You ought to start a new topic.
The previous poster wanted to add his cooker hood to the DOMESTIC LIGHTING CIRCUIT which is itself fused to only 6Amps. If you were coming off a ring or radial you would have to fuse it down, normally through an FCU. 3A would be ample if it was the only load.
A switched socket is a strange way to connect a fixed appliance like a cooker hood. And it should not be fitted out of sight where a person would not be able to see and isolate it in an emergency, like the hood sparking or catching fire. |
