Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Posted: Sat Jan 17, 2004 3:59 pm Post Subject:
doubt if you will get a reply from Tony01 he posted that on 5th dec and has never been back (look under his name and it shows only 1 post, which you were looking at)
But back to your question, it depends on where you live, London costing more, why not get several quotes its the best way
__________________ Do you like music Mr Finch?
Forum = Opinions
Joined: 05 Dec 2003 Posts: 2 Location: United Kingdom Thanked: 0 times
Posted: Mon Jun 28, 2004 1:14 pm Post Subject:
Nicola
Yes the cost for a 12m x 16m roof area costs £3840. This is for slate only.
If new timber is required I should add another £1200.
These costs include labour but exclude VAT.
Tony
Joined: 10 Sep 2002 Posts: 765 Location: United Kingdom Thanked: 0 times
Posted: Mon Jun 28, 2004 10:08 pm Post Subject:
Tony's original posting was asking for a " ballpark cost " and to this end any similar quote for the area stated is going to be useful to someone who wants that kind of work done. I know that there are lots of variants that can affect quotes but someone who has no idea of a price to start with could have thought 10-15k was the going rate for a 4k job. If the general public can be advised on a forum like this of a " ballpark cost " then it helps prevent the wool being pulled over their eyes by the masses of unskilled cowboy tradesmen that prey on the uneducated (construction wise) and especially the elderly and give a bad name to the rest of the decent contractors. Obviously the simple solution is to obtain several quotes as mentioned earlier but if a rough estimate is all someone wants then they will treat it as such and not be surprised if it differs due to the aforementioned reasons.
Joined: 08 Mar 2003 Posts: 347 Location: Cornwall, United Kingdom Thanked: 0 times
Posted: Fri Jul 02, 2004 3:05 pm Post Subject:
Masona, you referred to slate tiles - which material do you mean, slate or tile?
You also referred to costs/m then added labor and materials - could you break it down?
This is not criticism, i simply want to know!
thanks
Joined: 05 Jan 2003 Posts: 10852 Location: Essex, United Kingdom Thanked: 7 times
Posted: Fri Jul 02, 2004 5:00 pm Post Subject:
No problem,
When I built my summerhouse last year, I made a lot of enquiry regarding difference type of light roofing tiles as I didn't want heavy tiles.
£15 to £20 per m2 was for slate tiles only then you need to add roofing felt & batten materials etc plus labour which I can't give as it varies in difference area.
The slate tiles I was looking was not even made of slate and can't tell the difference, I think it made of some sort of hard plastic material.
I decided to go for metal tiles effect sheeting instead.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
