hope someone can help this seem a weird one.
The burner on the boiler keeps going on and off whithin 10 second intervals. The thermitor has been checked and appears to works correctly and also the air presure switch. The boiler has been cleaned to make sure it wasnt blocked and make sure the water was clearing but the problem just wont go. Its has if the burner is stoping due to the boiler being at operating temp but it is only just getting hot on the out pipe just before is turns the burner off. There is no fault coming up on the front display and the boiler is just over a year or so old. Any ideas much appreciated.................
Cheers
Cheers
