DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
kitchen tap
This topic originated from the How to page called Replacing a washer in a tap
Click here to return to the page called Replacing a washer in a tap.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
sagleo
from United Kingdom
Thanked: 0 times
PostPosted: Thu Mar 30, 2006 10:35 am    Post Subject:
kitchen tap
Reply with quote Thanks
The cover on the handle of our hot water kitchen mixer tap has come off, it never fitted properly since the plumber installed it. I see that a few of the \\\"teeth\\\" inside this cover are missing...would I be able to replace just this cover, or would I have to replace the entire tap?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
gcol
from United Kingdom
Thanked: 12 times
PostPosted: Thu Mar 30, 2006 10:52 am    Post Subject:
You can get universal replacement tap handles, but you'd probably struggle to get a match and so would need to replace the cold one as well. Is it a washer type or ceramic? Reason I'm asking is because if it's ceramic (and therefore more or less maintenance free), then could you not glue the handle to the tap mechanism?
Back to top
 Alert Moderators
sagleo
from United Kingdom
Thanked: 0 times
PostPosted: Thu Mar 30, 2006 11:08 am    Post Subject:
It is a washer type, chrome mixer tap. Underneath the cover is a screw. If I were to glue the cover on (with super glue?) would I be able to remove if needed at a later date?
Back to top
 Alert Moderators
gcol
from United Kingdom
Thanked: 12 times
PostPosted: Thu Mar 30, 2006 12:31 pm    Post Subject:
Hang on a minute here..... are we saying the plastic cap has fallen off the handle? I thought you where talking about the brass splined hole on the underside of the tap handle.
If it's just the cap icon_rolleyes.gif then just apply a few very small drops of glue around the edges. You might actually be better using a small amount of silicone to hold it in place.
If you go down the glue route, make sure you apply it by dipping a screwdriver into it and dabbing a small dot here and there around the rim.
Back to top
 Alert Moderators
sagleo
from United Kingdom
Thanked: 0 times
PostPosted: Thu Mar 30, 2006 2:09 pm    Post Subject:
Thank you very much for your kind and prompt advice and suggestions, I will use the silicone to attach the cover. Thanks again. icon_biggrin.gif
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Running gas supply to kitchen island through floor 4 320 Thu Mar 27, 2008 12:15 pm
Poor pressure in Kitchen tap 3 140 Tue Mar 25, 2008 12:09 pm
Drain kitchen taps but save hot water in cylinder? 5 360 Mon Mar 24, 2008 1:10 pm
kitchen ceramic monobloc tap leaking 4 340 Mon Mar 24, 2008 1:08 pm
Replace kitchen tap 10 400 Wed Apr 02, 2008 4:47 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
