gew1977
Joined: 02 Apr 2006 Posts: 2 Location: United Kingdom Thanked: 0 times
Posted: Sun Apr 02, 2006 2:10 pm Post Subject: double oven cooker and hob |
i have just installed a double oven and a electric hob (6 kw). I have come from the fuseboard(40amp) mcb in 10mm cable and into a 45 amp cooker switch. from there i have run cable down (10mm cable) into a junction box and was wondering can i double up the oven and the electric hob into the junction box? help is greatly appreciated |
cozycats
Joined: 08 Nov 2005 Posts: 105 Location: United Kingdom Thanked: 0 times
Posted: Sun Apr 02, 2006 6:39 pm Post Subject: |
Yes min 4mm cable but I can' see you're going to get all those cables into a jb. consider using a 47mm double surface patress with blanking plate and 60a choc block connector strip (which you won't find in B&Q) |
gew1977
Posted: Mon Apr 03, 2006 4:36 pm Post Subject: |
cheers copycatz, i just needed re assurance , and i have the 60 amp block and double backbox and blank plate, cheers for your reply mate, much appreciated |
