Removing a double glassed unit
2 Apr 2006
Aberdeen
Hi
Can someone tell how to get a double glassed unit out of a PVC window (CR Smith)
Thank you any help would be appreciated
One side of the window will have beads which pop off with the help of a couple of filling knives,the other side will have a wedge gasket(rubber seal) or security tape.
I'm guessing u will have wedge gasket if so remove this first prying out gently with a flat screwdriver works for me then the unit will be loose,nows the time to pop the beads off and carefully remove your unit.Refitting is the opposite using a clean peice of wood maybe to tap the wedge gasket back in last off all.
If security tape is used its normally on the inside and you will see it between the unit and frame normally 2-3 mm thick post back if you have this and i will try to help out (its almost as simple).
following on from sashwizard, if they are gasket type, it helps to lubricate the gaskets before re-installing, as this is how they would have been when new. oh, don't forget which way round the gasket goes as both sides are similar but not the same.
and take out or put back the longest sides last as they have the most flexibility
Hi
Thank you all for you help, will be having a go at this in the next few weeks need to get the new units made first
Thanks again
You will have to take out the old unit to get the correct size
Height X width X thickness, any glass above 800mm from floor level must be toughened.
JonB
