DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Pinning spindles
This topic originated from the How to page called A new look for existing stairs
Click here to return to the page called A new look for existing stairs.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
Fliss
from United Kingdom
Thanked: 0 times
PostPosted: Sun Apr 09, 2006 9:22 am    Post Subject:
Pinning spindles
Reply with quote Thanks
Hello
I have a bracket fix stair system - all going well, but about to start the spindles. On the accompanying video, it says "the spindles are held in place by the fillets and glue" (i.e. the spindles are just glued in) but in the printed instructions it says "cross pin and glue spindles". Does it matter if they are just glued? If I do need to pin them, what size nails should I be using? Do they go in at 90 degrees to the rail through the spindle? And finally, should I be using the same size nails to go through the fillets and do these nails have a head or are they the invisible type?
Thanks very much. Hope someone can help.
Helpline closed on a Sunday!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
masona
from United Kingdom
Thanked: 7 times
PostPosted: Sun Apr 09, 2006 12:48 pm    Post Subject:
The idea of the pins is hold the splindles in place while the glue is drying. You don't have to if you're using spacer blocks in between. I normally use veener pins as you can't see them being very thin. Make sure you wipe the glue 100% if you're going to wax or stains them.
__________________
Always judge a man by the way he treats someone who is of no use to him
Back to top
 Alert Moderators
chappers
from United Kingdom
Thanked: 0 times
PostPosted: Wed Apr 12, 2006 7:08 am    Post Subject:
if you are using a grooved rail to take your spindles with wooden fillets between then there is no need to nail the spindles just nail the fillets.
You only need to nail if the spindles are on flat base/hand rail.
Back to top
 Alert Moderators
big-all
from United Kingdom
Thanked: 24 times
PostPosted: Wed Apr 12, 2006 7:58 am    Post Subject:
i agree you only pin the "spacers"
if you try and pin the spindles because of the angles concerned the spacers act like wedges and will lift up as you try and pin the spindles in
even if you can keep the spacers flat because your nailing diagonals the tendancy is to "encourage"the top of the spindle to tighten towards the bottom of the stairs and the bottom to tighten up the slope towards the top of the stairs
thus forcing them out of line
__________________
big all
we are------------------ all still learning
Back to top
 Alert Moderators
Fliss
from United Kingdom
Thanked: 0 times
PostPosted: Wed Apr 12, 2006 1:32 pm    Post Subject:
Thanks, everyone. In the end, we started by not pinning, but ended up having to at the top of the spindles as the top rail was sagging in the middle and it seemed the only way to keep the spindles vertical as we were going along (we had to push the rail up). It probably would have been possible to get them into the vertical position by adding the next spacer and pinning it, though. Anyway, job done! Now on to removing the paint from the stairs.....
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
alternatives to pinning quadrant over laminate? 3 460 Tue Apr 18, 2006 5:44 am
Wobbly stair rail and spindles 2 600 Mon Nov 19, 2007 4:22 pm
Gaps Between Stair Balustrades (Spindles) 3 880 Sun Dec 02, 2007 11:02 am
Replacement stair spindles 2 420 Tue Nov 18, 2008 1:04 pm
FIXING SPINDLES: 4 220 Wed Sep 23, 2009 8:11 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
