hoover logic 1200 help
16 Apr 2006
Merseyside
Hiya..Happy Easter,
We have a hoover logic 1200 and it is washing ok draining fine but the cycle is stopping before the main spin. Its not working even if the dial is turned manually.
I was reading comments before and will try the filter but can you tell me where to locate it...Mother has took the back off the washing machine but where still stuck (cant see it).
Thanx for any advice, specially if given this morning.
Michelle xx
If it has a filter it'll be on the front of the machine, sometimes behind a plastic panel on the bottom. However, if it's draining fine it's not going to be the filter. It could be any of a number of things gone wrong. Motor, module, timer, pressure switch, wiring, etc. Best bet is to get an engineer in to diagnose and quote for repair.
Thanx for the reply....thought it may be the timer although it seems to be turning..till the last minute. Sure you got no other helpful hints to help us before we pay out millions :oops: Is there any majic buttons to push to make it spin??
Michelle xx Thanx again
When it's washing, does the drum actually turn? or are you assuming it washes ok because the clothes are wet?
Is there a rinse hold (or similar) button pressed in?
To be honest, from your description it's likely to be any number of things (as mentioned above). Unfortunately, without seeing the machine it's nigh on impossible to diagnose.
