| Author |
Message |
Glyn1959
Joined: 23 Jan 2003 Posts: 153 Location: United Kingdom
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
Thermo
Joined: 21 Oct 2004 Posts: 9982 Location: Sussex, United Kingdom Thanked: 148 times
Posted: Wed Apr 19, 2006 12:50 pm |
a few stupid questions.
Has it got a choke and are you using it and then taking it off?
try starting it with the air filter removed, it may be clogged up.
try fresh petrol, but to be honest i never have much of a problem with petrol when its left in any machinery, always seems to start pretty easily. |
| Back to top |
Static
Joined: 20 Dec 2005 Posts: 1943 Location: Sussex, United Kingdom Thanked: 155 times
Posted: Wed Apr 19, 2006 1:50 pm |
You could try replacing the petrol, and its probably a 2stroke engine so will need 2stroke oil to run |
| Back to top |
Alandy
Joined: 21 Apr 2006 Posts: 3 Location: Derbyshire, United Kingdom
| Back to top |
ratm
Joined: 26 Feb 2006 Posts: 96 Location: United Kingdom
Posted: Sat Apr 22, 2006 9:35 pm |
Had the same problem a few years back but I couldn't tell you what caused it, maybe bad fuel, maybe a worn plug. Most newer Flymo mowers are 4 stroke and don't have a true choke. They use instead a bulb type fuel purge that lifts a little extra fuel into the intake to aid starting. This dries as soon as the engine fires up and theoretically the engine should run on fine, however for some reason this isn't always enough and you need to choke the air intake a little until the engine warms up a bit. I've also noticed that if the fuel level gets down a bit or if the blade isn't clear of the glass it can be hard to start them. The fuel bulb needs to be pumped at least 10 times but don't try starting immediately after a stall, let it rest for a minute or two, for some reason they don't like starting when hot. |
| Back to top |
steelypies
Joined: 19 Apr 2010 Posts: 1 Location: United Kingdom
Posted: Mon Apr 19, 2010 10:57 am |
if your petrol lawnmower is a 2 stroke ,put 2 or 3 capfulls of oil mixed in with te petrol and it should work fine |
| Back to top |
Static
Posted: Mon Apr 19, 2010 11:03 am |
| steelypies wrote: | | if your petrol lawnmower is a 2 stroke ,put 2 or 3 capfulls of oil mixed in with te petrol and it should work fine |
Chances are in 4 years his garden is probably a little beyond a lawn mower if he hasnt fixed this problem.. |
| Back to top |
jaydodds100
Joined: 23 Mar 2011 Posts: 9 Location: Yorkshire, United Kingdom
Posted: Wed Mar 23, 2011 11:03 am |
I had the same problem after it had been stood over the winter. I removed the airfilter to start and topped up the oil - worked for me! |
| Back to top |
ClevelandSteamer
Joined: 26 Feb 2011 Posts: 8 Location: Argyll, United Kingdom Thanked: 1 time
Posted: Sun May 29, 2011 2:19 pm |
My new lawnmower is doing this. Think the mrs let it run out of fuel so hopefully its just needing a good prime?
My hedgetrimmer does this to though. Maybe the fuel could do with getting changed.
From reading this thread it sounds like the machines with the priming bulb don't need the oil added to the fuel. Is that right?
Should just stuck to electric machines ha ha |
| Back to top |
Burnerman
Joined: 07 Feb 2008 Posts: 8123 Location: Northumberland, United Kingdom Thanked: 1638 times
Posted: Sun May 29, 2011 6:01 pm |
Garden machines that have priming bulbs have carburettors with no float bowl, which enables the engine to run inverted, unless it is the design (Briggs) that has the fuel tank beneath the carb. The bulb is simply a manual pump that primes the carburettor with fresh fuel, hopefully for a good start up.
The engines may be two stroke (oil added to the fuel) or four stroke (no oil added to the fuel). Either may have a priming bulb. The exception to this rule is the Stihl 4 mix, which although a four stroke, does have oil added as a lubricant.
John  |
| Back to top |
ClevelandSteamer
Posted: Sun May 29, 2011 9:55 pm |
Oh man. This means I'm gonna have to hunt for the manual... |
| Back to top |
ClevelandSteamer
Posted: Mon May 30, 2011 5:17 pm |
Thanks for the advice
Got it goin eventually with clean fuel. Just kept at it...
went and got oil and a mixer thingy so all good now  |
| Back to top |
toffeemanchocky
Joined: 31 May 2011 Posts: 6 Location: Lancashire, United Kingdom
Posted: Tue May 31, 2011 2:04 pm |
it could be just too much oil in the fuel mix,drain and fill with correct amount of two stroke oil,approx 85ml in a gallon of petrol,always shake the can before filling,if this fails, take out the spark plug, clean, check if sparking, if yes, the get a normal lead pencil, rub the electrode withe the pencil lead,put it back in,WILL start as gives the engine a KICK Start,works on all petrol powered tools,used it loads of the time, old farmers trick ??? |
| Back to top |
stevehuws
Joined: 29 Mar 2011 Posts: 40 Location: Gwynedd, United Kingdom Thanked: 1 time
Posted: Tue May 31, 2011 10:28 pm |
| Back to top |
