My Apollo has cut out and now won't ignite (it's a self-igniter). It did this a few weeks ago and after flicking the thermostat switch a few times it ignited just fine, but now nothing seems to work. Any ideas?
I'm not sure of the system. The first time it cut out, a fuse in the mains was tripped out, but when that was replaced, it worked fine. A couple of weeks ago (before it went for the first time) the fan was making 'tinny' noises, and now it's failing to kick in as it should just before ignition. Therefore, I think it's either an electrical fault or the fan's knackered! What do you reckon?
