DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
2 plugs into 1
This topic originated from the How to page called Installing a power socket
Click here to return to the page called Installing a power socket.
  View previous topic :: View next topic
Author Message
doonballoon
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 24, 2006 11:05 am    Post Subject:
2 plugs into 1
Reply with quote Thanks
Hello. Have exchanched a 2 plug socket for a 1 plug socket. How should I treat the \\\'unwanted\\\' L, N & E wires from the 2nd plug? Thanks
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Har_vey
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 24, 2006 11:31 am    Post Subject:
Were the "unwanted" cables connected into the "2 plug socket" before you started?
If that's the case then they need to go into the "1 plug socket" as well.
I'm not sure I have that right though, so if you could explain your problem again, just to be sure?
Back to top
 Alert Moderators
Pens
from United Kingdom
Thanked: 0 times
That’s an unusual question.
When you say a 2 plug socket I assume you mean a double. If that’s the case it will only have 3 terminals, L-N-E. If it’s wired on a ring circuit you will have 2 lives, 2 neutrals and 2 earths in each of the terminals.
When you say 1 plug socket I assume you mean a single socket which also has 3 terminals. This would be wired in the same way, both the lives in L, both the neutrals in N and both the earths in E.
Have I interpreted your question correctly?
Back to top
 Alert Moderators
doonballoon
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 24, 2006 12:57 pm    Post Subject:
A Double socket into Single socket
Thanks for getting back!! Very bad terminology by me... I'll try again...
I have removed a double plug wall socket and replaced with a single socket.
There were two cables feeding the double socket, one of which is now feeding the single... for the other cable, I have wrapped the L, N & E individually with insulated tape and plastered behind the wall.
I have been advised that this is not best practice and that there is a plate which I should connect the disused wires to and which is then plastered over. Are my tape-wrapped wires at risk?
Hope this helps??
Back to top
 Alert Moderators
Pens
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 24, 2006 1:04 pm    Post Subject:
The double socket was fed by 2 cables because its wired to form a ring circuit. BOTH of the cables need to be connected together in your new single socket as stated above.
You must retrieve the other cable and connect it as you no longer have a ring circuit.
Back to top
 Alert Moderators
doonballoon
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 24, 2006 1:07 pm    Post Subject:
Many thanks!!
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue Apr 25, 2006 7:50 pm    Post Subject:
Re: A Double socket into Single socket
FFS.
What on earth made you think you were safe to work on electrics when you don't possess the tiniest amount of knowledge?
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
doonballoon
from United Kingdom
Thanked: 0 times
PostPosted: Wed Apr 26, 2006 9:40 am    Post Subject:
I know. So you can imagine my surprise when I landed the job of Senior Electrical Engineer at Wembley Stadium !!
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 22 times
PostPosted: Wed Apr 26, 2006 1:48 pm    Post Subject:
the mind boggles.
Back to top
 Alert Moderators
Gaz the Sparky
from United Kingdom
Thanked: 0 times
PostPosted: Thu Apr 27, 2006 9:39 pm    Post Subject:
the mind boggles why you would want to exchange a double socket for a single you could always not use the second socket !!!!!! icon_rolleyes.gif icon_confused.gif
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Thu Apr 27, 2006 9:45 pm    Post Subject:
Bit of a downward move after T5, surely?
__________________
Back to top
 Alert Moderators
doonballoon
from United Kingdom
Thanked: 0 times
PostPosted: Fri Apr 28, 2006 8:32 am    Post Subject:
Gaz TS ... not only am I a master electrician.... pause .... but a top carpenter too!!
I built a set of wardrobes that overlapped one of the sockets, rendering it completely pointless.[/quote]
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 9 times
PostPosted: Fri Apr 28, 2006 8:53 am    Post Subject:
Doonballon...Well first post I have read 2day that made me smile, are you still doing the plumbing course or was the pilots license first. icon_lol.gif icon_lol.gif
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Kitchen Plugs ? 3 540 Sun Jan 07, 2007 2:40 pm
European Plugs 11 820 Sat Mar 24, 2007 6:49 pm
Plugs, fuses and ratings 9 760 Thu Oct 12, 2006 3:48 pm
13 Amp Plugs/Ring Circuits 14 1020 Thu Aug 31, 2006 11:14 am
plugs 2 480 Wed May 17, 2006 11:14 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
