| Author |
Message |
water works
Joined: 27 Apr 2006 Posts: 1 Location: London, United Kingdom
Posted: Thu Apr 27, 2006 10:29 pm |
I have a radiator that has ugly pipes that run all the way up the wall in the living room. I want to chase them (bury them) in the wall. How do I go about doing this?
Any advice much appricated! |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
Softus
Joined: 21 Oct 2004 Posts: 19557 Location: United Kingdom Thanked: 8 times
Posted: Thu Apr 27, 2006 11:44 pm |
| Back to top |
oilman
Joined: 16 Sep 2003 Posts: 7965 Location: United Kingdom Thanked: 26 times
Posted: Fri Apr 28, 2006 5:13 am |
But don't use one of those unless you have one of these. Burying pipes in a wall is asking for trouble, I suggest you look at this instead, go to Pipes and Fittings, then Pipe Cover Systems. |
| Back to top |
Softus
Posted: Fri Apr 28, 2006 6:52 am |
oilman is utterly right, naturally. I meant to say something similar in my post (no, really, I did), but got distracted and when I came back I just clicked 'Submit'.
Burying pipes is a good way to annoy a heating engineer at the very start of a job, and to make anyone who sees it less inclined to want to work on your house it. My advice is to avoid doing it. For example, if you can run the pipes to the corner of the room then trunking up the wall at that point will be less obtrusive. |
| Back to top |
Agile
Joined: 26 Jun 2004 Posts: 46035 Location: London, United Kingdom Thanked: 2525 times
Posted: Fri Apr 28, 2006 8:44 am |
"""I meant to say something similar in my post (no, really, I did), but got distracted and when I came back I just clicked 'Submit'"""
You could always have used the edit facility later! |
| Back to top |
oilman
Posted: Fri Apr 28, 2006 5:15 pm |
| Agile wrote: | """I meant to say something similar in my post (no, really, I did), but got distracted and when I came back I just clicked 'Submit'"""
Bit like using the quote facility instead of """"""""""""""  |
| Back to top |
Expertboy
Joined: 22 Mar 2006 Posts: 235 Location: United Kingdom Thanked: 2 times
| Back to top |
Softus
Posted: Fri Apr 28, 2006 9:37 pm |
| Agile wrote: | | """""""""""""""""""You could always have used the edit facility later!""""""""""""""""""" |
Thank you. |
| Back to top |
Nige F
Joined: 28 Jun 2005 Posts: 15466 Location: United Kingdom Thanked: 716 times
Posted: Sat Apr 29, 2006 4:28 pm |
| Expertboy wrote: | Just box them in  | Pendock? ready made profiled boxing  |
| Back to top |
