dishwasher not draining nor completing cycle
22 Dec 2003
I have a Phillips/Whirlpool dishwasher, probably 7 or 8 years old. I don't have a manual for it. It gets about halfway through a cycle and then gets stuck. The dial stays in the same spot and the machine continues to run indefinitely. Also the thing is not draining. Anybody know what is happening to me?
I've not had a Phillips dishwasher, but have fixed similar problems on a Zanussi and a Bosch. If your problem is the same as I have had, it's all down to congealed fat collecting and then blocking either a "siphon thingy", (technical term), or the waste pipe. Lovely job. If you are able to inspect the float valves, water pressure sensors etc you may be able to see where the problem lies.
Good luck and a happy Christmas.
Philip.
dishwashers are NOT waste disposal m/c's
did you know before putting anything into a dishwasher you are supposed to rinse it under the tap first, this removes surplus fats etc that may block a m/c
did you also know the pink stain on any plastic parts is caused by tomato ketchup
useless but true
I need to find the electrical scheme for the program circuit of an Hoover dishwasher 7000 model D7420. Can you help me?
I would appreciated it.
Regards
Isabel Pereira
Elvas - Portugal
