Joined: 05 May 2006 Posts: 2 Location: Bournemouth, United Kingdom Thanked: 0 times
Posted: Fri May 05, 2006 5:03 pm Post Subject:
The water is running into the toilet bowl all the time - I think it's called ghost-flushing. There's no blockage but the man in the shop where it came from said to clean the filter as we live in a hard water area. The instructions given to do this were a bit vague and we don't want to break anything.
Will go to the shop for a demonstration at the weekend
Joined: 28 Jun 2005 Posts: 7494 Location: United Kingdom Thanked: 31 times
Posted: Sat May 06, 2006 9:21 am Post Subject:
Well it`s the weekend and Derek Acorah rang me last night and said the ghost is causing the flap valve -.not the filter- to not seat properly but Sam told him it could be chalk deposits
Joined: 21 Oct 2004 Posts: 19532 Location: United Kingdom Thanked: 6 times
Posted: Thu May 18, 2006 6:52 pm Post Subject:
First step - take off the cistern lid.
Actually there's a prior step - ignore the idiotic advice from joe-90.
Next - look at the water level. Is it higher than the top of the flush valve and therefore overflowing over the top? If so then the float valve isn't shutting off, in which case service or replace it.
If the level is not higher, i.e. water isn't overflowing, then the flush valve isn't sealing.
Either of these can be caused by grit/debris. If the flush valve isn't new, then the sealing washer/flap can harden and spoil the ability to seal. If you know what make it is then the chances are you can get a replacement seal. If not, then I'd cut my losses and fit a new one of a known make.
Joined: 03 Jul 2006 Posts: 4 Location: United Kingdom Thanked: 0 times
Posted: Mon Jul 03, 2006 10:21 am Post Subject:
1 You can check if it is a a leaking inlet by removing the cistern cover and gradually adding water (use a glass/cup etc). You should be able to add a few inches of water until the overflow activates.
2 If you put some coloured toilet cleanser around the bowl, you will probably see trace ripples to indicate that it is the washer on the flushing mechanism leaking - try cleaning it up and also the cistern where it seats.
3 A 'new' problem I have found is that it seems OK but when I screw in the cistern flushing screw, this can activate the flow of water into the bowl (presumably by exerting pressure onto the flushing mechanism). Has anyone else experienced this and how can it be cured except by hacksawing off the screw end or only partially tightening the screw ?
Posted: Mon Jul 03, 2006 12:39 pm Post Subject:
desktop, you've posted on an old topic, and it's actually difficult to tell whether (a) you're trying to help the OP, or (b) you're trying to get help on a new problem, or (c) you ]are the OP.
Posted: Mon Jul 03, 2006 2:03 pm Post Subject:
roca push button cistern
No - I'm not the Op (who I hope has now resolved his problem),
My remarks re the screw on the cistern lid promoting the apparent slight raising of the washer on the flushing mechanism are a new slant on this and I would be grateful for any advice.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
