Piperony
Joined: 08 May 2006 Posts: 2 Location: Manchester, United Kingdom Thanked: 0 times
Posted: Mon May 08, 2006 7:49 pm Post Subject: Connecting to alcathene pipe |
I am told that the mains water supply pipe entering my house is an old type alcathene pipe (about 22 mm OD). How do I connect a metric (22 mm) compression fitting to it? Can I use Hep2O pipe inserts for 22 mm pipes? Can I use 22 mm olives or do I need 3/4" ones? |
keego
Joined: 07 Feb 2005 Posts: 631 Location: Liverpool, United Kingdom Thanked: 0 times
Posted: Mon May 08, 2006 9:02 pm Post Subject: |
If it black alcathene then it will be imperial, also there are different types or classes of pipe C & D were the most popular.
Cut a section out & take it with you to the merchants, you will need a special fitting for it as well as an insert for that class of pipe, you can't just use 22mm conex fittings on it. |
Piperony
Posted: Tue May 09, 2006 6:24 am Post Subject: |
Thanks very much, Keego. It is black alcathene indeed. |
doitall
Joined: 08 Jan 2005 Posts: 9933 Location: Bath, United Kingdom Thanked: 240 times
Posted: Tue May 09, 2006 5:17 pm Post Subject: |
It will also have class C or D on the side of the pipe in green or blue writing. |
