I've got a worcester 240 which is overheating and firing the overheat stat in the hot water mode. C/H is fine and modureg, sensors and overheat stat have all checked out. The hot water flow rate is around 9L per min at around 55 degrees - which from the sevice data is fine. The C/H side was recently power flushed but has failed to solve the problem. Could the primary flow thru the calorifier be blocked ? If so does anyone have any ideas for un-blocking this or is a new one the only option ?
thanks
dave
thanks
dave
