I'm hoping that someone will read this and instantly give me some advise. A couple of weeks ago my ariston combi boiler had a bit of trouble with hot water. The water it pumped out was luke warm and the boiler itself overheated after about 15 seconds and then restarted after it had cooled down a bit. The central heating worked fine. I'd come to the conclusion that a blocked diverter valve was backing up the hot water and causing the over heat. I'ld planned to look at this problem this weekend but Friday the whole system would'nt work. I've cleaned the diverter valve (full to bursting with radiator rust) which not seems to work fine. However there is still no flame with either hot water or central heating. I have not yet check for a blocked pump but no gas or ignition seem to be getting to the business end. Does one not work with out the other and would a block pump stop all of this. Sorry to go on, any help.
