Joined: 20 May 2006 Posts: 8 Location: United Kingdom Thanked: 0 times
Posted: Sat May 20, 2006 12:38 pm Post Subject:
blowing bulbs
i just installed a four way switch..it controls a blue light of 50 watts perfectly. but i put in a regular bulb or a fluorescent for which i designed this switch, it blows the lightbulb immediately!!!
i have double checked the wiring many times and the controls work perfectly (for the blue light).
any help is appreciated...
topic moved as poster is in Canada
Joined: 01 May 2006 Posts: 637 Location: United Kingdom Thanked: 1 time
Posted: Sat May 20, 2006 5:02 pm Post Subject:
Isn't blue light something they used in the 60's where you can write stuff that is only visable using blue light. Thinking of the film gone in 60 seconds.
Posted: Sun May 21, 2006 3:20 am Post Subject:
uh, i meant just that: a blue light (not a red, not a green, and not a black). these are simple 40watt lights with colors on them. and somehow they blow.
now i went out and bought new sockets and installed it--the lights are fine, but the circuit tester i have says that the positive and neutral wires are reversed. They are not. Might the tester be saying this because it is a four way connection (three switches controlling one element)???
Posted: Sun May 21, 2006 11:04 am Post Subject:
nothing confusing here. the reader says that the positive (aka,the hot wire) and neutral are inversed--but they are not. is this reading do to the fact that it is a four way connection? if you are confused, don't respond.
i just need to know why the circuit reader would say that the positive and neutral wires are inversed when they are not?
Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Posted: Sun May 21, 2006 11:16 am Post Subject:
disfasia wrote:
nothing confusing here. the reader says that the positive and negative are inversed--but they are not. is this reading do to the fact that it is a four way connection? if you are confused, don't respond. i just need to know why the circuit reader would say that the positive and neutral wires are inversed when they are not?
Its your terminology that is wrong
its live (orphase) and neutral NOT posative and negative
and what is a "circuit reader"
it makes sense to you because you wrote it
__________________ Do you like music Mr Finch?
Forum = Opinions
Posted: Sun May 21, 2006 11:28 am Post Subject:
yes, the socket tester has three lights. but i am testing a socket for which there is four-way wiring... so would this be the reason for the reading? since putting in the new socket (the old one might have been corroded) things work perfectly--except for the reading.
Posted: Sun May 21, 2006 11:48 am Post Subject:
yes, i installed a four way system: three switches one light. that's all. i have the wires to the light linked to an outlet to test my lights before i blow another fluorescent.
power box: 14/2 to first switch
first to second and second to third switch: 14/3 (the 1st and 3rd are 3way switches, the 2nd a four-way).
3rd switch to socket: 14/2
i have checked and rechecked the wiring... I wasn't until i installed a new socket yesterday that the bulbs stop blowing out. but the socket reader still says the positive and neutral are reversed...
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
