controller unit
4 Jan 2004
I have an old surface mounted controller unit that has the oven cable coming out of the bottom. I need to move and replace this unit with a more modern one and bury the cable. I need to move it about 18 inches. Can I can some form of cable connector to extend the wiring or must I renew the lot? :D
change the lot :( it must also be the same size as you have now (probably 6mm)
