Zanussi Aquacycle 1000
6 Jun 2006
Surrey
Help,pleaseeee!
Got the above m/c which started making a funny noise whilst spinning. Closer inspection I could see sparks coming from underneath. The faster it spun the faster it sparked! After one more essential wash it has now stopped, any ideas anybody :?:
Sounds like the carbon brushes on the motor.
Unplug the machine and titl is backwords so you can get underneath from the front.
On the motor you'll see the carbons, in a black holder, 1 either side of the motor with a wire going to each.
Remove the 2 screws holding each carbon in place and you'll find they are worn.
Buy a new pair and replace the same way you removed, should now spin fine.
Cor Blimey that was quick!!!!!!
Many thanks will try that in the morning when i can see properly, and will leave a reply so others can capitalise on this wonderful forum!
Cheers
haveing kinda same problem , would like to know if this would cause all lights in front light up before i start pulling it apart ty in advance
