- Joined
- 6 Jan 2004
- Messages
- 20
- Reaction score
- 0
- Country
I have bought a 22mm compression fitting mid position diverter valve to replace the faulty one on my system, but want to be sure about the task before I start to do the job (it is winter after all!).
In the past when replacing compression fittings I have sometimes found that the olive has cut into the pipe such that a section of pipe needs to be replaced at the same time, being a 3-port valve in a complex part of the plumbing system this would be a tricky job. Is it acceptable to re-use the old olives thereby not disturbing any plumbing or is this asking for trouble?
For info, both old and new valves are Honeywell, with identical mechanical and electrical features even though the part No is different. The fault is such that the valve has difficulty going to the CH-only setting, taking a long time and doing a lot of buzzing.
