Servis Caress 1000 Not spining
11 Jun 2006
Birmingham
my washing machine has decide to no longer spin or move on cycles and my clothes are coming out soaking wet, i have checked all inlet and outlet pipes a nothing seems blocked i am in despair as i have only had this machine for 16 months and need to get it repaired very cheaply. SOME ONE PLEASE HELP!!!!
{Breezer scratches chin}
hmm, you have a problem with no spin?
you could also say you have an appliance problem that is common?
:idea: look in the most common appliance problem and cures section then
I have looked in the most common problems but nothing matches mine, they are either not spining or missing cycles nothing with a problem of both not spining in the cycle or the spin!
I am sorry but i am not a mind reader, so i can only go by what you type on the forum, so i am not to know that you did look in the common problems section first.
I also suggest you go back and read it again, as you did say no spin, which is mentioned in the afore mentioned section.
often one thing causes another not to work, so i suggest you start with no spin
