DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Bathroom extractor wiring again!!!
This topic originated from the How to page called Installing wiring for an extractor fan
Click here to return to the page called Installing wiring for an extractor fan.
  View previous topic :: View next topic
Author Message
poacher72
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jun 11, 2006 4:33 pm    Post Subject:
Reply with quote Thanks
Hi folks,
I decided to replace my old extractor fan with a flush mounted one, problem is - the old one had its own feed & its own integral switch(yes it WAS that old).
Should I use the original L & N (this has an isolator switch in the loft & feed from fuse box) as permanent L & permanent N. Then take the switched live from the existing bathroom pull cord switch?
Would this work? The new fan is from b&q, has an internal light & timer.
Sorry for long post & any help is greatly appreciated.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Sun Jun 11, 2006 4:39 pm    Post Subject:
If you're going back to the light switch, there is a lot to be said for rewiring with new. Not only will the cable not be old and perished, it will be obvious to anyone working on it or replacing the fan in future how it works. Someone might incorrectly think they could isolate it at the switch.
Back to top
 Alert Moderators
poacher72
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jun 11, 2006 4:43 pm    Post Subject:
You've lost me on that one!
The wiring is good, not long had it checked(last 2 years) reason I say that the fan was old is because it had its own pull switch over the bath.
Hope this is clearer.
(Just read your post properly & see what you mean icon_eek.gif )
Back to top
 Alert Moderators
poacher72
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jun 11, 2006 5:20 pm    Post Subject:
Initially I was thinking of using the bathroom light pull switch & the light itself but I don't think it would be feasible.
Anyone any recommendations?
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Sun Jun 11, 2006 8:38 pm    Post Subject:
Re: Bathroom extractor wiring again!!!
Internal light? That is intended for ceiling mounting, yes? With the feed to the light from the pullcord for the bathroom?
Yes, what you say will work, but you need to install a triple pole iso to safely switch off the fan supply.
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
poacher72
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jun 11, 2006 9:04 pm    Post Subject:
Should have added that the ight is powered off the fan via a transformer (12V light).
All feed would be going to the fan.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Bathroom Extractor - Wiring ? 11 420 Thu May 28, 2009 11:20 am
Newbie:- Wiring for a bathroom extractor fan 4 960 Mon Sep 19, 2005 10:57 am
help wiring replacment bathroom extractor fan 10 380 Sun Aug 31, 2008 3:59 pm
Wiring bathroom extractor to old fashioned lighting circuit 6 9980 Thu May 17, 2007 4:13 pm
Bathroom Extractor Fan Wiring 8 340 Wed Jan 21, 2009 10:42 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
