wirlpool wont drain HELP!!!!
21 Jun 2006
wirlpool quite wash wont drain fills up and moves water but wont drain off. pulled hose at elbow and see no block ready to check further down the line but am open for some HELP OR SUGGESTIONS
PLEASE HELP :cry: :cry: :cry:
Is the motor running or trying to run when the washer is supposed to be draining? If so, check that drain hose for kinks or blockage. There should be a good flow of water coming out of the hose during the drain mode. If your washer is dead and no motor is running, check for a bad lid switch.
Found blockage and all is running well THANK YOU THANK YOU :p :p :p :LOL: :D :eek:
