DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
1 gang to 2 gang
This topic originated from the How to page called Replacing a one way light switch
Click here to return to the page called Replacing a one way light switch.
  View previous topic :: View next topic
Author Message
darkblue
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jun 22, 2006 6:20 pm    Post Subject:
1 gang to 2 gang
Reply with quote Thanks
changing a 1 gang 2way to a 2 gang 1 switch 2 way (ceiling light) 1 switch 1 way downlighters.2 cables on existing switch 1 with black L2, Red L1. 1 With Red Com,Yellow L1,Blue L2.How do i connect up the 2nd switch icon_confused.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Adam_151
from United Kingdom
Thanked: 10 times
PostPosted: Thu Jun 22, 2006 6:47 pm    Post Subject:
transfer wireing from existing switch to one half of new switch, wire your new light (??) to the other half of the switch (you can other take the feed through the switch, or loop in somewhere and drop a switch branch to the switch)
Not sure I really udnerstand the question tbh...
Back to top
 Alert Moderators
darkblue
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jun 22, 2006 6:55 pm    Post Subject:
I've done that and ceiling light is working as normal. I'm left with the cable going to the transformer 2 wires brown & blue and an empty switch. what to do now.
Back to top
 Alert Moderators
Adam_151
from United Kingdom
Thanked: 10 times
PostPosted: Thu Jun 22, 2006 6:58 pm    Post Subject:
Well you need a feed that you can switch onto the transformer cable, you can most likely bring switched live from one of the terminals of the other switch to common, connect the live to the transformer to L1, the neutral from the transformer is going to be the sticking point, its unlikely that you have a neutral at the switch (do you have some blue or black wires in a choc block behing the switch?)
Best way would be to drop down another T&E that picks up power from a JB on the lighting circuit
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
1 Gang 2 Way dimmer switch problem 2 380 Tue Nov 06, 2007 1:05 am
2 gang dimmer 3 300 Sat Oct 27, 2007 4:07 pm
2 GANG SWITCH REPLACEMENT 5 340 Sat Oct 27, 2007 1:00 pm
Three gang 2 way light switch help! 18 700 Mon Oct 22, 2007 10:30 pm
Do 1 To 2 Gang Socket Converters Work ok 4 220 Mon Nov 05, 2007 8:29 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
