DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Noisy Pipes in loft ensuite shower
This topic originated from the How to page called Planning a shower
Click here to return to the page called Planning a shower.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
csiagos
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jun 23, 2006 12:27 pm    Post Subject:
Reply with quote Thanks
I recently had a loft conversion and the rest of the house replumbed and a new worcester bosch boiler installed on the bottom floor. The middle floor shower has a mixer where you turn the handle round to activate the shower with a tap in the middle of it to regulate the temp. The same setup is in the shower in the loft ensuite. The difference is that in the loft ensuite, when you turn on the water, the pipes make a whirring sound. If i turn on the tap in the ensuite basin then the sound dissipates, i guess due to less pressure being in the pipes. Could the mixer be causing this or is it just becasue it is higher up than the middle floor shower that the water has to travel further thus more pressure? I took of the shower head and the sound is still there but not as bad.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Expertboy
from United Kingdom
Thanked: 1 time
PostPosted: Fri Jun 23, 2006 12:48 pm    Post Subject:
If possible look on the pipe runs up to the shower thats making the noise for isolating valves, try regulating them.
If this isn't the case a little more information on the noise would be helpful:
Is it a whistling noise?
Water gushing noise?
Banging noise?
__________________
i accept no responsibility for any of your mistakes whether you took my advice or not icon_smile.gif
Back to top
 Alert Moderators
csiagos
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jun 23, 2006 4:09 pm    Post Subject:
Hi there,
It is a water gushing noise, but quite high pitched. I haven't tried playing with the temperature setting on the mixer but it seems that the water is trying really hard to get out of the shower head, and that there is not as much pressure as i would expect.
I can't get to the pipes but i'll see if i can hear exactly where the noise is starting from.
Cheers
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
New ensuite. Can I use Combi for hot & cold from loft ta 4 300 Mon Feb 20, 2006 11:35 pm
New bedroom/ensuite - add on to existing pipes? 3 420 Sat Feb 24, 2007 5:54 pm
installing shower tray in ensuite 4 1360 Fri Sep 07, 2007 6:23 pm
ENSUITE SHOWER NOT WORKING 10 400 Thu Oct 16, 2008 12:03 pm
Bathroom & ensuite refurb - types of shower advice pls! 6 440 Thu Jul 10, 2008 9:00 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
