Joined: 02 Jul 2006 Posts: 11 Location: Sussex, United Kingdom Thanked: 0 times
Posted: Sun Jul 02, 2006 12:16 pm Post Subject:
Boxes in Breeze block
Are there any guidelines for the maximum depth of box which can be cut out of a breezeblock. I have two breeze blocks supporting part of the roof of an extension, and therefore cautious about weaking the supporting wall. I need a 35mm single lighting box cut out to 25mm. Would I be ok to do this ?
Joined: 04 Jun 2006 Posts: 198 Location: Kent, United Kingdom Thanked: 0 times
Posted: Sun Jul 02, 2006 6:29 pm Post Subject:
If you want to cut out a square for your box, do you already have either a hole for cable entry or do you intend to chase the blocks as well? and...how high are these blocks?
Posted: Sun Jul 02, 2006 10:00 pm Post Subject:
Hi, Maybe I should post my question on the general building forum. Box is to be cut out from breeze block. Cable will lie on the surface of the breeze block. Quite simple. Not rocket science. Simple question.
Joined: 04 May 2006 Posts: 134 Location: United Kingdom Thanked: 0 times
Posted: Sun Jul 02, 2006 10:04 pm Post Subject:
If you're worried about it, surface mount the box. If you're not, chase it into the wall. Personally I'd chase it into the wall. Simple. Not rocket science.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
