DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Light Fitting
This topic originated from the How to page called Types of electrical circuits
Click here to return to the page called Types of electrical circuits.
  View previous topic :: View next topic
Author Message
snake7
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jul 06, 2006 3:07 pm    Post Subject:
Light Fitting
Reply with quote Thanks
I went to fit a new light in a bedroom,it has 3 red,3 black and 3 earth wires,the 3 red are a loop as far as i can see,2 of the black are neutral and 1 black is live.
I fitted the new light, went to switch it on and it went bang blowing a main fuse.
Re-wired the light again using connectors,this time no bang but the light stays on all the time even when the switch is off,can you please help..thanks.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
johnny_t
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jul 06, 2006 3:12 pm    Post Subject:
Where have you got the light connected across ? It should be between the single black wire (switched live), and the two black wires (neutral).
Alternatively, if you originally connected the switch up incorrectly between permanent live and neutral, you may have b*ggered it.
EDIT: I'm assuming the wires you describe above are at the ceiling rose with no light present.
Back to top
 Alert Moderators
snake7
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jul 06, 2006 3:21 pm    Post Subject:
yes the wires are at the ceiling rose.
I have fitted the brown wire of the light fitting to the single black [live] and the blue to the 2 black [neutral] and the 3 red wires all together in a connector..
erm,the only thing is i put a new switch on aswell,do you think it could be that as the light fitting wires look right..
Back to top
 Alert Moderators
Adam_151
from United Kingdom
Thanked: 10 times
PostPosted: Thu Jul 06, 2006 3:26 pm    Post Subject:
Is it a dimmer switch?
Back to top
 Alert Moderators
snake7
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jul 06, 2006 3:29 pm    Post Subject:
Its not a dimmer,its a one gang one way
Back to top
 Alert Moderators
johnny_t
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jul 06, 2006 3:49 pm    Post Subject:
The wiring sounds right. Do you have a multimeter to help chase down the problem ?
Back to top
 Alert Moderators
snake7
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jul 06, 2006 4:02 pm    Post Subject:
just phoned my wife to get one as she works in a DIY store,will check the wiring then let you know....thanks for all your help most appreciated. icon_wink.gif
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
New light fitting - double insulated 4 480 Fri Jun 15, 2007 8:41 pm
Live and neutral not marked on light fitting 5 380 Tue Jul 07, 2009 12:34 pm
bathroom light fitting 6 400 Sun Jun 17, 2007 10:14 am
kitchen light fitting - which way round? 7 520 Fri Sep 09, 2005 3:00 pm
Trying to find a light fitting 3 260 Tue Nov 20, 2007 12:34 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
