DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
stairs
This topic originated from the How to page called A new look for existing stairs
Click here to return to the page called A new look for existing stairs.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
Dave123
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 12, 2004 9:53 am    Post Subject:
stairs
Reply with quote Thanks
I have taken down a wall to open up the stairs and I am left with just the steps how do I go on from here to fit base rail hand rail and spindles Thanks
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
GwaiLo
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jan 18, 2004 5:21 pm    Post Subject:
Richard Burbridge do a bracket specifically for DIY use. See here
I assume you did get building regulations consent for this work? Is so the BCO will probably give you a bit of advice for nothing.
If not there is every chance that you will have to put the wall back or face problems if you ever want to sell you home.
Removing walls, particular opening up stairs, can have a seriously detrmental effect on fire spread and means of escape.
__________________
This is not advice. Seek professional advice. I accept no liability errors or omissions.
Back to top
 Alert Moderators
mark v
from United Kingdom
Thanked: 0 times
PostPosted: Tue Feb 03, 2004 11:47 pm    Post Subject:
more info
If the wall is just a stud partition and not a brick supporting wall then you should be ok without regs but if it is masonry then like GwaiLo said, you could have a problem if you come to sell your property later. you should be ok on the fire regs unless your house is three stories high of if there was a fire door which was separating the ground floor from the first floor. A good tip for fitting spindles is to put the amount you need in and measure the distance left, then divide this by how many spaces you have (1 space more that the amount of spindles) and this will give you the correct length for the spacers but make sure that you cannot pass a 90mm sphere between the spaces in the spindles because of regs again. ( it says 100mm but i've recently heard that it has been reduced to 90 just to be on the safe side)
One last note, it is always advisable to check with the local authorities about any building work to prevent any suprises later on down the line and for piece of mind.
Back to top
 Alert Moderators
salem2000
from United Kingdom
Thanked: 0 times
PostPosted: Wed Feb 11, 2004 12:12 am    Post Subject:
Please bare in mind that stud walls can also be support walls and Fire Breaks.
__________________
1010011010
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
Laying laminate on stairs advice 4 1160 Tue Aug 07, 2007 9:57 pm
help with stairs..please!! 3 300 Sun Jul 08, 2007 2:43 pm
stairs 5 4261 Sun Jun 24, 2007 1:24 pm
Repairing stairs with visible right angle metal strips? 2 1340 Thu May 17, 2007 12:12 pm
Old Manhattan Stairs 5 320 Tue Aug 21, 2007 7:15 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
