Joined: 12 Jul 2006 Posts: 1 Location: Monmouthshire, United Kingdom Thanked: 0 times
Posted: Wed Jul 12, 2006 8:04 pm Post Subject:
outside taps
want to put in outside tap - what size drill should I use for 15mm pipe work and what size/type of casing to put pipe through - also what is best product to seal hole afterwards
Joined: 21 Oct 2004 Posts: 19532 Location: United Kingdom Thanked: 6 times
Posted: Thu Jul 13, 2006 11:51 pm Post Subject:
Re: outside taps
16mm is enough for 15mm tubing, but sometimes I drill a 23/24mm hole and sleeve the 15mm tube in a short length of 22mm Hep2o pipe.
Or you could drill to 16mm and use one of these beauties:
Posted: Fri Jul 14, 2006 12:50 am Post Subject:
You seem to making it a habit to answer questions with questions.
Bamber gaspipe wrote:
Did I suggest a backplate combined with a copper tail?
No.
Quote:
.... show me..
Show you what? The Edit button? The Spell Check button? The error of your ways? Please be specific.
Quote:
and what is your trade...
What has that got to do with anything?
Quote:
A water pipe does not enter an outside wall... it exits
As you wish - enters, exits, who gives a sh*t - the principle is the same, and you're either stupid or deliberately misunderstanding, but neither is important as long as mikeyboy2 understood me.
Quote:
Why would I need to sleeve a waterpipe thru a wall?
If you read the topic you'll see that mikeyboy2 asked what type of casing to use. I didn't say that you, or indeed anyone, needed to sleeve it, I simply answered his question (with an answer, not another question).
Joined: 03 Jul 2006 Posts: 1279 Location: United States of America Thanked: 0 times
Posted: Fri Jul 14, 2006 1:01 am Post Subject:
You are skirting the issue...please tell me your trade...or I will make this a `General Topic`issue..& questioning your right once & for all as to wether you should be giving advice on the way that people install their Central Heating or the way that people scratch their Ar*se....are you frightened Mr. D.I.Y.er
Joined: 14 Jun 2004 Posts: 771 Location: United Kingdom Thanked: 0 times
Posted: Fri Jul 14, 2006 9:55 am Post Subject:
well now a GOOD competent plumber would use a large drill bit 24mm sleeve the pipe in the same material as is passing through the wall seal the entry/exit with a suitable material,fit internal isolation,fit the bibcock in such a way that the pipe empties when isolated inside to prevent possible freezing and do not forget a non return valve after the internal isolation.hope this helps
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
