DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Sealed CH drain-down puzzler
This topic originated from the How to page called Removing a radiator
Click here to return to the page called Removing a radiator.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
fiveminutejob
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jul 16, 2006 3:18 am    Post Subject:
Reply with quote Thanks
I want to replace a downstairs radiator in hall, needing small adjustments to pipes at each end for new one - so valves will have to come off. (Rads have been extended at different times ; now connected to a newish Vaillant Thermocompact sealed system boiler hanging on integral garage wall). Most rads up and downstairs have TRVs. Have shut off valves, TRVs and lockshield nuts to all rads, then drained down from drain point at base of kitchen rad,leaving drain hose open to outside. Boiler fill loop is set to off. Pressure now zero.
Problem is that hall rad keeps refilling and overflowing clean water from its opened air bleed vent - and I can't figure out a) where it's coming from and b)why it's not finding its way out first via drain hose which seems lower. If I open up hall rad TRV I get about a cupful every 10 mins - for hours!. Have checked all other rads are shut off both ends. Could this just be TRV seepage from other rads? Would decorators caps on all TRVs help? Faulty refill loop? Any thoughts welcome. Thanks
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Bamber gaspipe
from United States of America
Thanked: 0 times
PostPosted: Sun Jul 16, 2006 4:49 am    Post Subject:
You have drained down the kitchen radiator & the flow & return legs to it.It won`t make much difference to your hall radiator. You need to empty that radiator & the legs to it...Do what you have done to the kitchen radiator, but do it in the hall..
Back to top
 Alert Moderators
fiveminutejob
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jul 17, 2006 9:16 am    Post Subject:
Thanks Bamber. I have tried to do exactly that - isolating hall rad and draining it but it keeps topping itself up. Only kitchen rad has a drain cock. I thought that would drain down all pipework, just leaving water in shut off rads. That's why I'm puzzled.
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Mon Jul 17, 2006 10:22 pm    Post Subject:
Have you got a normal HW cylinder? If the coil in it is letting-by, water comes out from the domestic system into the heating system, and it would go down whichever pipe were closest. Half a cup in 10 mins sounds about right for that.
In this weather the trv should shut though!
Hard to prove a leaky coil; turn off the mains input and don't use any tank water for as long as poss and see if the level drops - by seeing if water inlet flows again when you turn the water back on. The level won't appear to drop much.
Back to top
 Alert Moderators
fiveminutejob
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jul 18, 2006 8:48 am    Post Subject:
Thanks Chris. Yes there is a 'normal' hw cylinder in cupboard on landing with a single tank in loft above it. If water was coming from cylinder, I would have expected it to show at drain hose outside. But when hose is dry, hall rad is still topping up. I'm wondering now if the pipework to the hall rad (an add-on by previous occupier) may be the problem, with no route to lowest drain point. All thoughts appreciated. Thanks.
Back to top
 Alert Moderators
croydoncorgi
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jul 18, 2006 10:16 am    Post Subject:
If you've left all the other rads filled and are relying on all the valves holding 100% and / or parts of the system becoming airlocked, at some point you have to admit defeat, open the drainoff and all the valves and airvents on the rads and drain the system completely. There usually only 10% chance that a system will airlock sufficiently to do work including removed valves with any confidence. And a slow let-by somewhere often creates too much volume to work easily without making a mess. Grasp the nettle - drain the beast.
And don't forget to add inhibitor when you refill.
Back to top
 Alert Moderators
fiveminutejob
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jul 18, 2006 12:50 pm    Post Subject:
Thanks very much cc. Armed with all your helpful responses, I guess a full drain down is the next step.
(This is a great site - so much knowledge and experience willingly shared. Thanks to all.)
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Shower extractor puzzler 5 240 Tue Jan 29, 2008 2:25 pm
central heating puzzler 2 300 Fri Mar 14, 2008 7:22 pm
drain sealed system 6 640 Tue Nov 07, 2006 1:06 pm
Drain sealed system with no drain valve 9 240 Fri Feb 06, 2009 8:14 pm
Draining sealed system. No drain off valve 13 880 Sat Feb 07, 2009 1:25 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
