DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Separate switch on fused spur circiut
This topic originated from the How to page called Adding a spur to a ring circuit from a socket
Click here to return to the page called Adding a spur to a ring circuit from a socket.
  View previous topic :: View next topic
Author Message
bazza_bing
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jul 19, 2006 11:10 am    Post Subject:
Reply with quote Thanks
Is it possible to add a switch to a fused spur light circuit? In other words, the sequence I am thinking of is - Mains circuit - Fused spur (not switched) - Separate switch - Lights? If so how should the switch be wired from the fused spur to the switch and from the switch to the lights, bearing in mind that the connections on the switch are L1, L2 and Common?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Wed Jul 19, 2006 11:12 am    Post Subject:
at the switch, connect the 2 browns to L1 and COM. Connect the blues to a piece of terminal block. Connect the earths to another piece of terminal block.
Back to top
 Alert Moderators
bazza_bing
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jul 19, 2006 1:44 pm    Post Subject:
Thanks,
Does this mean I can use the same method for a dimmer switch, instead of a normal switch?
Back to top
 Alert Moderators
Adam_151
from United Kingdom
Thanked: 10 times
PostPosted: Wed Jul 19, 2006 1:54 pm    Post Subject:
Yes, also in addition to what crafty says, remember to earth the backbox if metal, and same goes for front plate if metal
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Wed Jul 19, 2006 5:05 pm    Post Subject:
i assumed plastic accesories . . . but i shouldn't assume, we all know what that does icon_rolleyes.gif
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
NEW SOCKET CIRCIUT TRIPPING THE RCD 17 800 Fri Jan 28, 2005 6:07 pm
Circiut Breaker Lockouts - Top Gadget!?! 4 480 Fri Jul 13, 2007 10:38 pm
Circiut Fault 17 980 Thu May 19, 2005 6:26 pm
Switch/separate fused unit order question 17 720 Sun Aug 21, 2005 4:18 pm
Heaters - spur or separate circuit? 29 480 Mon Jun 29, 2009 10:04 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
