donetello
Joined: 23 Jul 2006 Posts: 10 Location: Sheffield, United Kingdom Thanked: 0 times
Posted: Sun Jul 23, 2006 12:05 pm Post Subject: Bathroom fan from two switches |
Putting in fan and would like to know if its possible and how to wire it so it works off both the light switch and the shower switch.Doing it this way so it can be used from either one. |
Steve
Joined: 15 Apr 2005 Posts: 12857 Location: Yorkshire, United Kingdom Thanked: 22 times
Posted: Sun Jul 23, 2006 12:11 pm Post Subject: |
no
unless you are familiar with relays, and a type of relay that can have 2 inputs to energise the controlled circuit. not sure if such an item exists, TBH. |
breezer
Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Adam_151
Joined: 17 Jun 2004 Posts: 4540 Location: United Kingdom Thanked: 10 times
Lectrician
Joined: 18 Jul 2004 Posts: 5166 Location: Devon, United Kingdom Thanked: 20 times
Posted: Sun Jul 23, 2006 7:58 pm Post Subject: |
Or you could simply and easily use double pole pull cords - one pole to switch the light, and the other pole to switch the fans sw-live. Fans pem live as normal.
Easy - this is how it is commonly done in commercial apps with a large heat-exchanger type fan ducted between gents/ladies/disabled etc. |
RMS
Joined: 08 May 2006 Posts: 409 Location: United Kingdom Thanked: 1 time
Posted: Sun Jul 23, 2006 8:08 pm Post Subject: |
Lectrician,
good idea, but would that mean you would have two supplys in the shower switch?
Nothing wrong with this ofcourse as long as it is clearly identified.
RMS |
