Hi
I seem to have two problems that are compounding each other. First my radiotors are coming on even when the heating system is set only to hot water. Reading some existing posts the most likely cause appears to be my 3 Port Valve or Reurn Valve. Fixing either of these is beyond me so I\\\'ll call a qualified plumber.
However:- In the interim I have been able to control the problem by shutting down the thermostatic valves on all the radiators. One radiator however cant be shut off. I\\\'ve tried all the usual tapping pushing/pulling the pin.
Am I wasting my time? Is there anything you can suggest?
There is a little silver box by my hot water tank labelled Honeywell 8941. It has a sprung lever that can be set to \\\"MAN OPEN\\\" with a notch at one end of its movement or Auto at the other. Whichever end the lever is at it remains there. Is this part of the problem?
Thanks for any help
As you can imagine the house is positively tropical at the moment....
Thanks for any help
