DIYnot
Local | Network
   DIYnot > Forums
Local | Network
replacement shower switch
This topic originated from the How to page called Choosing a shower
Click here to return to the page called Choosing a shower.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
gandmb4647
from United Kingdom
PostPosted: Thu Jul 27, 2006 2:24 pm Reply with quote
have come to replace shower pull switch. wired as usual but then it blew for some reason. have tried wiring again but no success. can anyone help please by providing diagram or any other help. thanks.
Back to top
 Alert Moderators
grrinc
from United Kingdom
Thanked: 1 time
PostPosted: Thu Jul 27, 2006 2:46 pm Reply with quote
You have got the correct sort I assume. It should be a 45amp double pole switch with a visible on and off indicator.
This should have a live and neutral 'feed' and a live and neutral 'load', and obviously an earth too. Your cable that comes from the consumer unit should go into the appropriate live and neutral 'feed' connectors. And the cable that connects to your shower go into the appropriate live and neutral 'load' connectors.
This is a whole lot of power that really shouldnt be messed about with. I am sure a sparky wouldnt charge much to do these connections for you safely.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
DIY replacement of Netaheat fan or pressure switch? 10 1660 Wed May 11, 2005 3:23 pm
Potterton Lynx 2 boiler water pressure switch replacement 3 1920 Wed Dec 05, 2007 7:43 pm
Worcester Bosch BF240 flow switch replacement 6 120 Sun May 15, 2011 12:23 pm
Switchmaster Blue VA1 3 port switch replacement 10 4660 Thu Mar 30, 2006 7:46 am
Switch master midi valve actuator replacement?? 5 3260 Thu Apr 27, 2006 5:00 pm
DIYnot
