Joined: 03 Aug 2006 Posts: 3 Location: Essex, United Kingdom Thanked: 0 times
Posted: Thu Aug 03, 2006 9:06 pm Post Subject:
connecting a timed fan and light
Hello
I have connected a bathroom timed fan in , i used a 3 pole switch so i can switch of the fan from outside of the bathroom.I have conected from ceiling rose to the 3 pole switch them using the switch wire to a pull cord switch and them to my timed fan.
The problem ,some where in this curcit i need to fit a light that comes on with the fan and switchs off leaving the fan to run on its timmer. can i simply connect into the same switch/connection as the fan to the neutral on my ceiling rose.
look forward to your response
Joined: 02 Jun 2005 Posts: 10887 Location: Cumbria, United Kingdom Thanked: 39 times
Posted: Thu Aug 03, 2006 10:01 pm Post Subject:
The old to new wiring colours for this will be:
2 core + earth cable
Red = Brown
Black = Blue
Blue wire needs to be sleeved brown in the switch wire for switch live.
3 core + earth cable
Red = Brown
Yellow = Black
Blue = Grey
Black wire needs to be sleeved brown for switched live and Grey wire needs to be sleeved blue for neutral.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
