DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
rendering/dashing the base of walls?
This topic originated from the How to page called Rendering
Click here to return to the page called Rendering.
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
  View previous topic :: View next topic
Author Message
my-house-is-falling-down
from United Kingdom
Thanked: 0 times
PostPosted: Sat Aug 05, 2006 1:33 pm    Post Subject:
Reply with quote Thanks
My house is completely pebbledashed.
Looking around at other pebbledashed houses there appears to be four approaches to how the bottom of the wall is finished.
1. Dash all the way to the base of the wall (i.e. where it meets the driveway/ground) or even below the level of the earth
2. Dash down to a bead/edge then render below the bead/edge to the drieway/ground
3. Dash down to a bead/edge then black paint below this to the ground (is this a special paint?)
4. Dash down to a bead/edge then clean brickwork below this to the ground
Does anyone know why/when these different approaches are taken please?
In some of these approaches, it seems the DPC is ignored and dashed/rendered/painted over? Does this no give rise to possible rising damp problems?
Does anyone know of a good guide to all this stuff?
Thanks in advance for any help/guidance you can give.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
jbonding
from United Kingdom
Thanked: 0 times
PostPosted: Sat Aug 05, 2006 5:56 pm    Post Subject:
You should fix bellcast beads a brick above the DPC and render to this then Clean the bricks up.The DPC should not be bridged. icon_wink.gif
Back to top
 Alert Moderators
legs-akimbo
from Ireland
Thanked: 2 times
PostPosted: Sat Aug 05, 2006 10:54 pm    Post Subject:
As long as the bellcast sits above the dpc there is no reason at all that what is then classed as the plinth can not be float finished rendered if the brickwork does not want to be seen.
Back to top
 Alert Moderators
jbonding
from United Kingdom
Thanked: 0 times
PostPosted: Sat Aug 05, 2006 11:33 pm    Post Subject:
Dont bridge the DPC with render or your gonna cause problems.
Back to top
 Alert Moderators
from United Kingdom
Thanked: 0 times
PostPosted: Sun Aug 06, 2006 10:14 am    Post Subject:
many thanks for the very quick replies. the reason for my question is that my walls are finished in two different ways and I'm trying to understand what is right and why before sorting them out icon_smile.gif
A wall adjacent to the drive had a bellcast, pebbledash above, float finished render below. Problem was level of driveway was suspected to be above dpc level. I've hacked off the render below bellcast to identify the true level of the DPC in this area, cut back through tarmac and concrete to make a 6" wide channel a few inches deep (this was very tough going!), angled to drains in middle and at ends. Apart from a bit of repointing above & below the DPC, I'm trying to figure out whether I should/could re-render below the bellcast. Seems there are conflicting views on this? Surely if I rendered across the DPC for cosmetic purposes then moisture can bridge the DPC and cause problems? (Or does the waterproofing agent in the render mix prevent this)
On the far wall, I dug down to the footings to see how deep they were. The pebbledash on this wall goes right down to the footings! I hacked a bit of this away as well and found the DPC (so I know one exists in this part of the house). What should I do on this wall? Immediately above the DPC, the wall appears to be of breeze block (or similar) so would have to be very careful when hacking off any pebbledash there as it seems to break the block icon_sad.gif Any ideas why this would have been done this way originally and what I should do about it?
Any advice would be most appreciated
Thanks.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
Safe to remove pebble dashing? 9 780 Mon Jul 19, 2004 12:29 pm
Pointer needed on flint rendering walls 13 440 Thu Jun 05, 2008 8:06 pm
Concrete base 3 620 Fri Aug 04, 2006 9:29 am
Timber base to inner leaf of cavity??? 2 500 Thu Aug 24, 2006 12:03 pm
Garage base 7 500 Mon Aug 28, 2006 9:22 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
