chrisqx
Joined: 08 Aug 2006 Posts: 1 Location: London, United Kingdom Thanked: 0 times
Posted: Tue Aug 08, 2006 8:58 pm Post Subject: Hot is too cold in winter |
I have a Grohe thermostat mixer tap where I can adjust the temperature and the flow rate separately. I winter I can't get it to run hot enough, even though I have set the temp as high as I can. It is not a problem with the hot water because I can get scolding hot out of the sink. It only happens on really cold days when the cold water is ice cold. I need to find a way to get to let less cold in and more hot, but I am not sure how.
I am not sure of the exact model but the insides look similar to this http://www.grohe-addon.com/additionalcatalog/files/tpi/95/t95453131-01.pdf
Can anybody tell me how to adjust this so I can get more hot water and less cold? |
GrahamT
Joined: 18 Jul 2006 Posts: 80 Location: Sussex, United Kingdom Thanked: 0 times
Posted: Tue Aug 08, 2006 10:08 pm Post Subject: |
If you have access to the pipework you could put a ballafix on the cold and reduce the flow with that |
superskanker
Joined: 11 Jul 2006 Posts: 49 Location: Manchester, United Kingdom Thanked: 0 times
Posted: Tue Aug 08, 2006 10:36 pm Post Subject: |
If its thermostatic you shouldnt need a balofix on it to regulate the flow. the thermostat will still mix it to the temp required. More likely the thermostat is nacked. __________________ The wifes decision is final and no correspondence will be entered into. |
