DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Hard Water Descalers - Electric / Electronic
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Firrip
from United Kingdom
PostPosted: Thu Aug 17, 2006 10:28 am Reply with quote
Hi
I've read a couple of posts that say these descalers don't work but I wondered if anyone has anything positive to say about them and, if so, which one?
I live in West London and my taps and sinks etc need constant descaling, so these would be a perfect solution, if one of them worked.
Any views?
F
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 46 times
PostPosted: Thu Aug 17, 2006 10:46 am Reply with quote
Nope no good words for them from this quarter
Back to top
 Alert Moderators
Alfredo
from United Kingdom
Thanked: 800 times
PostPosted: Thu Aug 17, 2006 11:53 am Reply with quote
The answer is that scale reducers do and don't work...which is probably not all that helpful.
What the electric/electronic devices try to do is the same as an in-line magnetic scale reducer..they impart a magnetic field to the water which changes the polarity of the ions in the calcium carbonate (scale). This has the temporary effect of changing the calcium carbonate from scale to a powder.. which can then pass through a combi plate to plate without scaling it up. Its no use for hot water storage cylinders as the polarity of the ions changes back after a very short time, and you are back where you started.
This part of lincs has very hard water and our in line scalemasters on combis seem to do the trick. We very rarely replace plate to plates for scaling these days, and we are five years into this contract, so they must do some good. On a conventional system scale is deposited when water temp exceeds 60c so we tend to keep cylinder stats below this figure..say 55c..which is enough to kill any bugs. Scale reducers are no good on this sort of application.
The only complete answer is a water softener..I have a Liff 2000..which very good..except it guzzles salt so is not cheap to run, but you soon know when the salt has run out and the recharge doesn't work properly.
I was assured by the technical guys at Glow Worm on our last visit that their tests showed that scale reducers do work, and most boiler manufacturers insist on one being installed with a combi.
Alfredo
Back to top
 Alert Moderators
Firrip
from United Kingdom
PostPosted: Thu Aug 17, 2006 8:04 pm Reply with quote
Alfredo - thanks for that.
Do you know what model Glow Worm use?
I'd rather not have to ask them directly, as I have a Glow Worm and I can't afford their premium call fees!
Thanks again.
F
Back to top
 Alert Moderators
chrishutt
from St. Pierre and Miquelon
Thanked: 20 times
PostPosted: Fri Aug 18, 2006 6:30 am Reply with quote
This is interesting - http://www.chem1.com/CQ/
Back to top
 Alert Moderators
cbservices
from United Kingdom
Thanked: 1 time
PostPosted: Fri Mar 13, 2009 4:41 pm Reply with quote
hot then cold hot then cold same old story yeh i know but will fitting one reduce scale before i need to remove heat exchanger and clean it manualy.?
Back to top
 Alert Moderators
simond
from United Kingdom
Thanked: 273 times
PostPosted: Fri Mar 13, 2009 5:31 pm Reply with quote
Most combi boiler manufacturers do not insist on limescale preventative devices. Would you care to name the ones that 'insist'?
Modern modulating boilers have a better temp control of the water in their heat exchangers. It is very uncommon for a DHW HeX to need descaling.
Partially blocked units are common but that is the magnetite debris from the rads on the boiler side.
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 46 times
PostPosted: Sat Mar 14, 2009 6:41 pm Reply with quote
Back to top
 Alert Moderators
twgas
from United Kingdom
Thanked: 421 times
PostPosted: Sun Mar 15, 2009 10:23 am Reply with quote
corgiman wrote:
Back to top
 Alert Moderators
Mogin558
from United Kingdom
PostPosted: Thu Jan 28, 2010 2:32 pm Reply with quote
What is this scalemaster please?
I am in west london and like others, I have a horrible time with scale.
I have a combi and a scalewatcher attached to the main pipe coming in, but I am not sure if this does the trick or not.
We still get scale so I am wondering if this scalemaster is better than the scalewatcher (or is it the same thing?)
Back to top
 Alert Moderators
LITTLEPLUMBER
from United Kingdom
PostPosted: Fri Feb 26, 2010 11:33 am Reply with quote
Well electronic descalers do work and I should know.
The real problem I have found is that you must determine whether your plumbing is VENTED or UNVENTED and this simply means "have you got a tank in the loft"?
If you have you'll need to treat the rising main AND the cold down service to the hot water cylinder. So many of these water conditioning Companies say ONE UNIT DOES THE WHOLE HOUSE but this is just not true.
Back to top
 Alert Moderators
Moderator 7
Moderator Comment
Posted: Fri Feb 26, 2010 1:25 pm    Comment:
Please note rule 3 (NO Free advertising.) - See here for the forum rules.
mointainwalker
from France
Thanked: 200 times
PostPosted: Fri Feb 26, 2010 11:42 am Reply with quote
Sorry, but the fact that you are making and selling something is no guarantee that it works.
As an example, to stick with this theme, there are dozens of rip-off merchants selling the clip-on permanent magnet devices to soften water/prevent scaling at prices as high as pnds 70 for something that costs less than 50 p to make and they don't work.
Back to top
 Alert Moderators
Mogin558
from United Kingdom
PostPosted: Fri Feb 26, 2010 11:45 am Reply with quote
We have a combi boiler so no tanks anywhere.
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 837 times
PostPosted: Fri Feb 26, 2010 1:05 pm Reply with quote
Yeah, But the Brocket Rocket icon_wink.gif Spitfire WW11 petrol power producing pellets DO work or I`ll eat my "Ride to Live" Harley-Davidson baseball cap icon_cool.gif
Back to top
 Alert Moderators
mointainwalker
from France
Thanked: 200 times
PostPosted: Fri Feb 26, 2010 2:17 pm Reply with quote
Quote:
Yeah, But the Brocket Rocket Spitfire WW11 petrol power producing pellets DO work or I`ll eat my "Ride to Live" Harley-Davidson baseball cap
Sounds really interesting NF. How much ? How far ? Why ?
Sooooooo many questions
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Descalers / Cleansers 5 540 Thu Jan 24, 2008 8:41 pm
Descalers 11 860 Tue Dec 07, 2004 5:35 pm
Hard Water (Electronic Fix) 8 680 Mon Nov 15, 2004 8:10 am
Hard water and inline heaters. 5 360 Fri Jun 04, 2010 2:32 pm
Hard or Soft water for CH system 4 360 Sun Mar 14, 2010 2:48 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
