DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Grout/Tile adhesive removal
This topic originated from the How to page called Ceramic floor tiles
Click here to return to the page called Ceramic floor tiles.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
catone
from United Kingdom
Thanked: 0 times
PostPosted: Fri Aug 18, 2006 12:49 pm    Post Subject:
Reply with quote Thanks
Having done a pretty good 1st job at laying ceramic floor tiles I grouted said tiles as per instructions and wiped with a damp sponge. Then, left to dry for an hour before re-cleaning only to find that the residue had stuck to the surface. Are there any ways of removing the residue of grout from the tiles?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Moz
from United Kingdom
Thanked: 0 times
PostPosted: Fri Aug 18, 2006 3:40 pm    Post Subject:
was it cement based grout or epoxy , if epoxy no chance now ....
if cement based ,you must get it off as soon as poss ,it will be a little tougher, but not impossible, to remove excess grout and the haze that are disfiguring your new floor......
Tools
a wooden block an the rough washing up sponges , two buckets/bowls one full of soapy water the other full of very clean water ,
get on hands an knees an rub wood block on big lumps an follow up with soapy sponges ,doing a foot square at a time , then clean with sponge an clean water ,Use old rags or a few paper towels to immediately dry the tiles
Back to top
 Alert Moderators
catone
from United Kingdom
Thanked: 0 times
PostPosted: Tue Aug 22, 2006 8:25 pm    Post Subject:
Great - thanks for the help!! Have given it a go and it's worked a treat. Phew!!
Back to top
 Alert Moderators
Moz
from United Kingdom
Thanked: 0 times
PostPosted: Thu Aug 24, 2006 12:10 pm    Post Subject:
catone
Back to top
 Alert Moderators
jesters3
from United Kingdom
Thanked: 0 times
PostPosted: Tue Apr 10, 2007 8:12 am    Post Subject:
Hi i'm a new user. Been searching for a way to do this as I left EvoStik Ceramic Concrete adhesive to the floor and it went like rock.
Your advice was spot on as it didn't make any scratches on the tiles and they buffed up really well.
Thank you very much Moz. Nice darts!
Back to top
 Alert Moderators
symi
from United Kingdom
Thanked: 0 times
PostPosted: Mon May 18, 2009 5:49 pm    Post Subject:
Had a problem with dried grout on new ceramic tiles, loads of washing didnt remove any. Found using neat white vinegar and wire wool shifted the lot.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
Adhesive Tile Removal 2 5540 Tue Jan 17, 2006 7:56 pm
Carpet adhesive removal 2 1280 Mon Apr 09, 2007 11:28 am
Removal of adhesive from floorboards before sanding 2 2460 Mon Jun 05, 2006 12:17 pm
bitumen adhesive removal 3 2140 Tue Feb 08, 2005 11:52 am
Old tile removal on cement floor 4 800 Tue Jan 31, 2006 1:46 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
