F.24 Water level low Pump obstructed, pump running at lower capacity,
Temperature rises too fast ir in appliance, system pressure too low,
flow and backflow NTC reversed
Probably needs more water -
3.11.2 Filling and make up
The system can be filled using the built in filling loop
(ecoMax 800 series only) or via a separate filling point
fitted at a convinient position on the heating circuit.
Many thanks to Fitz1 and ChrisR. Bar pressure OK but sometimes drops slightly and I top up. Looks like I need to call in an expert, but now I have an idea what the problem is they cannot take advantage of me and say I need a new boiler. Any good honest central heating repairers in the West Bromwich/Birmingham area out there, please post a reply.
