Joined: 20 Aug 2006 Posts: 2 Location: United Kingdom Thanked: 0 times
Posted: Sun Aug 20, 2006 6:31 pm Post Subject:
wiring ceiling roses
I have removed a fluorescent tube and installed a light with a ceiling rose in my kitchen. My first time so I forgot to mark the wires The light works fine, but the switch won't turn the light on and off. I have four live (red) wires, 2 black (neutral) and 1 earth (yellow + green) to work with.
All suggestions as to how to identify the switch wires gratefully received.
Joined: 18 Mar 2005 Posts: 605 Location: United Kingdom Thanked: 0 times
Posted: Sun Aug 20, 2006 8:28 pm Post Subject:
but basically three red together (only one of the two core red cable) one red of the two core red cable to the live of the light and the two blacks to the neutral of the light all earths together
Posted: Sun Aug 20, 2006 8:48 pm Post Subject:
breezer, yes but unless its a wind up, i am just assuming this person has read a little and is just trying to sound more switched on (pardon the pun) than they really are. i get a bit fed up with this site and drift in and out sometimes for a month or two at a time, but there is something satisfying to help someone who is willing to have a go.
Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Posted: Sun Aug 20, 2006 8:52 pm Post Subject:
i am only replying to the question that was asked, he may want to know how to identify the switch cable, in which case my reply stands, and since that is what he asked, he did not ask where does each cable go, since he knows one is the switch cable, he just wants to know how to find out which it is
__________________ Do you like music Mr Finch?
Forum = Opinions
Joined: 28 Mar 2004 Posts: 6930 Location: United Kingdom Thanked: 15 times
Posted: Sun Aug 20, 2006 9:29 pm Post Subject:
ok you mentioned 4 red wires are two of them from the same cable if so they are almost certainly your switch wires.
if both are solid red then connect them either way round, if one is actual red insulation and one is black insulation sleeved red then the convention is to use the red as permanent live and the black sleeved red as the switched live.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
