Hoover WDM120(01) door disassembly
28 Aug 2006
Nottinghamshire
Hello there,
The door hinge on our Hoover WDM120(01) snapped this morning (a nice surprise after we've had around a dozen friends and family members to stay over the last week and have a huge backlog of associated laundry to do).
It looks like this should be a reasonably simple and inexpensive this to repair; the part seems to be readily available on the web. My problem is that I can't for the life of me see how to take the door apart to be able to fit a new hinge into it. I have undone and removed the 4 torx screws in the door, but the two plastic halves do not want to pull apart. I have tried prizing the two pieces apart, but they are pretty firm and I don't want to break anything.
Does anyone have any suggestions or experience that might assist me, please?
Many thanks,
Adam
Hello there,
Many thanks,
Adam
No problem and don’t be scared Adam, just put two (2) flat blade screwdrivers under the hinge lugs through the hinge recess and lever out evenly, if you still feel nervous as you lever out; just follow the small gaps as they appear on each side with another flat blade. All will be well I promise.
By the way try not to take the whole cover out, just about halfway will do; it will save you the work of putting back the spring plunger and door hook afterwards.
