DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Refitting a radiator on a combi-system
This topic originated from the How to page called Removing a radiator
Click here to return to the page called Removing a radiator.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Debbie m
from United Kingdom
Thanked: 0 times
PostPosted: Tue Aug 29, 2006 1:08 pm    Post Subject:
Reply with quote Thanks
My partner drained and removed our lounge radiator in order for us to clean and decorate behind it.
We have replaced it on the brackets but just need to know whether the rad will fill up with water automatically? We haven't a water tank - we have a combi-system.
Any advice please?
Debbie
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Bahco
from United Kingdom
Thanked: 5 times
PostPosted: Tue Aug 29, 2006 4:04 pm    Post Subject:
Check out the faq thread above for advice in refilling a sealed system. icon_biggrin.gif
__________________
85 weeks without smoking!
Back to top
 Alert Moderators
GeeTee
from United Kingdom
Thanked: 0 times
PostPosted: Tue Aug 29, 2006 5:37 pm    Post Subject:
Personally.....
Do it with the heating off.
Having connected both feed and return pipes (keeping the valves shut), open the bleed valve on the radiator then open either the feed or return valve a turn or so. Keep a towel handy.... eventually all the air will be expelled from the rad and you should get a flow of water from the bleed valve instead of air..... this would be a good point to close the bleed valve!
This should minimise the amount of air that gets circulated around the rest of the system.
Open the feed and return valves as necessary - referring to the notes you made about how many turns it took to close the lockshield valve icon_eek.gif
Top up the pressure as per the FAQ.
Ta
Graham
Back to top
 Alert Moderators
Bahco
from United Kingdom
Thanked: 5 times
PostPosted: Tue Aug 29, 2006 5:40 pm    Post Subject:
__________________
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Refitting a radiator 6 220 Fri Nov 21, 2008 7:08 pm
Should I add anything to the water when refitting a radiator 2 260 Fri Jul 11, 2008 10:08 pm
Boiler will not fire up after refitting a radiator. 12 540 Sat Dec 01, 2007 8:58 pm
Radiator Refitting / Balancing help. 2 160 Sat Dec 13, 2008 10:22 pm
No heating and noisy pumps after refitting a radiator 5 480 Wed Feb 22, 2006 8:42 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
