Frigidaire Wash Machine not spinning
30 Aug 2006
Frigidaire Wash Machine is not spinning or agitating.
I beleive I hear the motor running and I can also spin the barrel by hand
If it is the belt, should I access the internals from the back or the bottom?
Is it easy to replace?
I would check the belt out first with these symptoms. I am not sure what model Frigidaire you have but it may be a combination of pushing in on the two spring clips between the top and front panels while lifting up on the top panel. Then locate the screws to remove the front panel. You may also have an older type washer with and access panel in the back of the washer. Good luck!
Thanks The model number is FWX6970EW1. So I can leave the Wash Machine Upright. Where would the screws for the front panel be located
I beeive my machine is approx 8-9yrs old. What is the life expectancy?
You can leave the washing machine upright. It appears you have two screws at the bottom of the front panel. After you remove them, pulling down on the panel should remove it. As for the life expectancy, its hard to tell. Although, in my estimation, I think the older washers are made better than the newer ones today. Hope this helps you.
Was there any resolution to this problem? I am currently having the same issue. I took the pump assembly off from the motor and it still does not start.
