A LEAKING GE WASHER (PROFILE PRODIGY)
3 Sep 2006
THE WASHER LEAKS WATER ALL OVER THE FLOOR DURING CERTAIN TIMES OF WASHING, CAN YOU HELP????????????
You have to find out where the water leaking from so you can identify the faulty part. You will have to remove the front panel by inserting a putty knife between the top and front panels and lifting the top panel up while doing so. Once you do that, pull the front panel forward and lift it out. Use a flashlight if nessacery to locate the leak.
