DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
new radiator is cold?
This topic originated from the How to page called Removing a radiator
Click here to return to the page called Removing a radiator.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
jingle68
from United Kingdom
Thanked: 0 times
PostPosted: Sun Sep 03, 2006 7:55 pm    Post Subject:
Reply with quote Thanks
i have fitted 2 new radiators,each one has a trv on one end and a shut off valve on the other.neither rad is heating up. should i have fitted lockshield valves? what is the difference between lockshield valves and shut off valves?. all the existing rads are working ok.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
tomy
from United Kingdom
Thanked: 1 time
PostPosted: Sun Sep 03, 2006 7:58 pm    Post Subject:
Provided you have connected them to the correct pipes you have an airlock .
Back to top
 Alert Moderators
rob884
from United Kingdom
Thanked: 2 times
PostPosted: Sun Sep 03, 2006 8:05 pm    Post Subject:
shut all other rads off to increase pump pressure to two rads.
lockshield are for balancing, shut offs are for completly turning off
Back to top
 Alert Moderators
jingle68
from United Kingdom
Thanked: 0 times
PostPosted: Mon Sep 04, 2006 9:10 pm    Post Subject:
found the problem, my 'helper' had closed the lockshield valve on the rad nearest the pump. as soon as i opened it, the two rads heated up!
Back to top
 Alert Moderators
bab
from United Kingdom
Thanked: 0 times
PostPosted: Mon Sep 04, 2006 9:15 pm    Post Subject:
if both rads go off with only 1 valve shut i think u may hav a little design fault. no need to have 2 trv;s in that case,
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 2 times
PostPosted: Mon Sep 04, 2006 11:09 pm    Post Subject:
oh dear I dont think you wanted to do that icon_wink.gif Babs is right, you may have cocked up a wee bit there
__________________
If at first you don't succeed, remove all evidence you ever tried.
Back to top
 Alert Moderators
jingle68
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 05, 2006 11:03 pm    Post Subject:
now im lost....what do you mean?
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Cold Radiator 2 260 Wed Nov 22, 2006 10:10 am
radiator downstaiors cold 12 620 Mon Nov 20, 2006 2:43 pm
Cold En-Suite Radiator 11 500 Mon Nov 13, 2006 6:39 pm
cold radiator at top of house 8 540 Sat Nov 11, 2006 4:17 pm
Cold Radiator 11 560 Sat Nov 25, 2006 11:27 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
