Air in HW Cylinder
10 Dec 2003
I had/have a very noisy HW Cylinder. There is a constant sound of running/sloshing water. I drained the cylinder (by turning off the water supply to the cylinder) by turning on the HW taps in the house. Once empty I refilled the cylinder and hey presto the noise stopped ...... for only 24 hrs. I think there must have been air in the cylinder, which I got rid of, but now it has returned, how do I permanently solve this problem??? (There is no bleed valve on the cylinder)
i am not a heating engineer or plumber but may i suggest you read this
as even to me your post seems lacking information
Do you mean the noise is CONSTANT? ie it NEVER stops?
When does the noise occur?
Is it only when the heating system is heating the water?
The operation that you did was to empty the cylinder and refill to get rid of air. Air in the cylinder gets out by going out of the top of the cylinder and up into a vent pipe to the cold water feed tank.
In response to oilman:
The noise is constant (never stops) when the HW is on. The moment I turn it off, the noise stops. It could therefore only be making a noise when it is heating, something I hadn't thought of (this is my first house and I'm therefore new to diy!).
There isn't a thermostat on the cylinder, in my old rented house there was, could it be that my cyliner is always being heated?? (just thinking aloud). But if that was the cause of the noise then it would have done it even after I had refilled the cylinder would it not?? I really don't know anything about plumbing and would be grateful for any tips that I could try. Thankyou.
