DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
showers
This topic originated from the How to page called Choosing the correct size cable
Click here to return to the page called Choosing the correct size cable.
  View previous topic :: View next topic
Author Message
tell12
from United Kingdom
Thanked: 0 times
PostPosted: Wed Sep 06, 2006 3:35 pm    Post Subject:
showers
Reply with quote Thanks
I AM FITTING A 8.5KW SHOWER WITH 10mm CABLE, CAN I USE A 32A FUSE OR SHOULD I USE HIGHER icon_eek.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
New2Game
from United Kingdom
Thanked: 0 times
PostPosted: Wed Sep 06, 2006 3:37 pm    Post Subject:
Taking into account for diversity, 32A will be fine
Back to top
 Alert Moderators
Pens
from United Kingdom
Thanked: 0 times
PostPosted: Wed Sep 06, 2006 3:41 pm    Post Subject:
8.5kw = 36.95 amps and you can't apply diversity to a fix load
You will need a 40amp MCB if you want a hot shower
Back to top
 Alert Moderators
tell12
from United Kingdom
Thanked: 0 times
PostPosted: Wed Sep 06, 2006 3:47 pm    Post Subject:
SHOWER CABLE AND FUSE
Back to top
 Alert Moderators
Pens
from United Kingdom
Thanked: 0 times
PostPosted: Wed Sep 06, 2006 3:51 pm    Post Subject:
Caps=SHOUTING...please don't shout
Why are you confused? You need a 40amp MCB...do the maths
8500watts / 230volts = 36.96 amps so a 32amp breaker is to small
Back to top
 Alert Moderators
tell12
from United Kingdom
Thanked: 0 times
PostPosted: Wed Sep 06, 2006 3:54 pm    Post Subject:
showers
sorry for the shouting,
pensdown, thanks for the advice will buy 40a fuse in morning icon_redface.gif
Back to top
 Alert Moderators
jondiy
from United Kingdom
Thanked: 0 times
PostPosted: Wed Sep 06, 2006 11:08 pm    Post Subject:
You should also ensure you have 30mA of RCD protection!!
35 or so Amps of Current - and Lots of Spraying Water = Potential Risk of Shock.
Fit your MCB to the RCD side of your consumer unit (if it has one), failing that, add a 40A 30mA RCBO (if you can get one that fits!) - or if not then fit a seperate shower CU by taking a 40A feed from your current CU , or if you can't do that then split the tails before your consumer unit and add the shower unit using Henley service blocks!
The bathroom is a special location - do you know this work should be notified to the council and also any work should be checked & tested.
Are you up to the job?? Are you also aware that if you don't have it tested then peoples lives are at risk , can you live with yourself knowing somebody electrocute themselves because your setup (FUSES!!!!) may not disconnect from the supply within the times specified by BS 7671 (0.4 seconds or 5 seconds!! - equipment dependent.
Why not get a spark in, ask him if you can run the cabling etc (under his supervision/guidance) - then get him to do the final connections and issue you with your test certs etc!
Would be worth it in my mind! But its up to you - your house!
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Thu Sep 07, 2006 4:08 pm    Post Subject:
Please don't post anything unless you are sure it is correct. It is very misleading, and confuses DIY'ers no end.
Who taught you that diversity can be applied to a fixed load? They want shooting, and you need to go back to college!
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 22 times
PostPosted: Thu Sep 07, 2006 6:16 pm    Post Subject:
well, if you average out the load the shower draws over a period of time, a 6 amp MCB would be plenty sufficient icon_wink.gif
Back to top
 Alert Moderators
mini2
from Ireland
Thanked: 0 times
PostPosted: Fri Sep 08, 2006 6:35 pm    Post Subject:
you know your stuff mate giving suggestions on many ways you can wire up a shower.
A property Developers ideal sparky- Everything is possible
btw the way i work out amps is 4amps to 1000watts very quick and simple way if you aitn got a calculator to do watts/230 volts
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
how to wire 2 electric showers on the same circuit 11 860 Fri Aug 17, 2007 8:41 pm
Renew showers kw?? 3 340 Sun Jul 22, 2007 11:08 am
Showers! 6mm T&E cable to be used for shower 6 860 Sun Aug 19, 2007 10:11 am
2 electric showers 2 300 Fri Aug 24, 2007 11:18 am
mira showers 6 320 Mon Dec 10, 2007 6:12 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
