Have a potterton gas wall mounted boiler in the attic, one cold water tank feeding a (vented) hot water cylinder with an emersion heater. Have not been using central heating over the summer but have just moved a rad and tried firing the system up to test for leaks.
Situation is complicated because I wasn't sure of refilling procedure if the rads weren't emptied: I keep them locked off as I heard this was a good idea, though on coming to fill the system it didn't go to plan!
So, now the boiler won't light, the pump is making promising noises and water is trickling from the rads when I bleed them. So I'm thinking maybe there's an airlock in the boiler?
Its powered off now, but I'd like to fix it tomorrow if poss...
... so I'm wondering, why didn't the system fill properly? Is it because the of the strange orange mini cylinder with what looks like a pressure guage and a fill loop (about 10 inches high and 12 wide, with a red knob on the top) ... could it be pressurised??! ... next to the boiler?
I've always kind of ignored its pressence in favour of assuming the central heating system was conventional, but now it seems I've got to bleed something else - the two pipes at the top of the boiler? Top up the orange thing? .. I'm beginning to wonder. (Didn't check the pressure before hand, currently just over 1.5...)
In the past to relight the boiler I just pressed reset. This now isn't working. Any suggestions much appreciated. I won't be able to post model numbers / photos until tomorrow evening.
Cheers chaps.
Cheers chaps.
